Script Help
hello,
i am new to mp3tag but i must say i am loving it's simple yet effective style! i need some help with a script i am trying to write.
i simply to need to set the title tag to be equal to the filename if and only if title is empty. how can i do this? (i am using the latest V 2.26)
thanks,
-prash.
Hi!
You can create a new action using the following properties:
Format value
Field: TITLE
Formatstring: $if($eql(%title%,),%_filename%,%title%)
Sebastian's formatstring uses the new syntax introduced with the current Development Build.
Best regards,
~ Florian
