Hi all,
I got stuck with an If operation. The script just stops without error (genrating output) but omitting code behind endif at least is case is negativ. Don't know behavior in positiv case since this is not reached.
Would be great you experts might have a look- most probably I'm just blind. Since code is for the "prohibited" source, I don't like to post the almost complete script. So find attached just the relevant part with the corresponding debug.
Thanks in advance!
Added some of the original line numbers in abbrev. for sync:
FindLine "sample" 1 1 # Kriterium für letzen Track finden (244)
MoveLine -1
unspace
IfNot "</html>" # ja:EOF (247)
MoveLine +2
Unspace
If "<th" # ja:weitere CD (250)
MoveLine -10
FindLine "<h2>tracks"
FindInLine "tracks"
outputto "CurDisc" # Discnummer zwischenspeichern
RegexpReplace "<.*?>" ""
SayRegexp "\d+"
EndIf
EndIF
#Disc-Number & Totaldisc ausgeben
outputto "Discnumber" #(263)
SayOutput "CurDisc"
# say "|"
Set "TOTALDISCS" # alten Wert löschen
outputto "TOTALDISCS"
SayOutput "CurDisc"
MoveLine +1
Unspace
While "<div class="ui360">" # ja: weitere Tarcks (272)
#endif
Trace dazu:
Script-Line : 242
Command : say
Parameter 1 : >|<
Output : >Koko Taylor|<
Line and position:
Koko Taylor
Script-Line : 244
Command : findline
Parameter 1 : >sample<
Parameter 2 : >1<
Parameter 3 : >1<
Line and position:
<td class="sample pick" title="AllMusic Pick">
Script-Line : 245
Command : moveline
Parameter 1 : >-1<
Line and position:
<tr>
Script-Line : 246
Command : unspace
Line and position:
<tr>
Script-Line : 247
Command : ifnot
Parameter 1 : ></html><
Line and position:
<tr>
Script-Line : 248
Command : moveline
Parameter 1 : >+2<
Line and position:
<div class="ui360">
Script-Line : 249
Command : unspace
Line and position:
<div class="ui360">
Script-Line : 250
Command : if
Parameter 1 : ><th<
Line and position:
<div class="ui360">
Total output:
