benc
January 20, 2018, 10:38am
1
Hello!
I would like to use Scripting functions in Web Sources Framework. Is it possible? For example something like this:
outputto "ALBUM"
say $left(%artist%,20)
(OK, it's a dummy example, it can be done in different ways, but there are more difficult cases than this.)
Thanks!
Florian
February 13, 2018, 8:54am
2
It's not possible at the moment.
Can you give a concrete example? Maybe we find a workaround for that.
benc
February 13, 2018, 8:49pm
3
Hey Florian,
Thank you for your answer.
I wanted to write the releasetime, this format: YYYY-MM-DD and from that write the date with a function this format: DDMM. So, using sayregexp for the releasetime and using a function for the date.
Fortunately I found another way. (It works with beatport):
#RELEASETIME
outputto "RELEASETIME"
sayregexp "(?<=releaseDate":")[^"]+" #YYYY-MM-DD
#YEAR
outputto "YEAR"
sayregexp "(?<=releaseDate":")\d\d\d\d" #YYYY
#DATE
outputto "DATE"
sayregexp "(?<=releaseDate":"\d\d\d\d-\d\d-)\d\d" #DD
sayregexp "(?<=releaseDate":"\d\d\d\d-)\d\d" #MM
