Here is what I would like to do. I have selected a folder in my Music directory. It display all songs from multiple albums from that particular artist. I would like a way to scroll to the next artist in my Music directory, display all that artist's music, etc. etc. With the ability to do this I could rapidly go thru my directory, view all songs from a particular artist, select all or some and edit the Genre or other fields as necessary. As it stands now, the Directory drop down box displays the past 10 selections that have been made. I like that feature too, but is there a possibility of adding another drop down box that will accomplish what I am asking?
Thanks
Rob
Yes. And you can edit that string, press enter to load the folder with the new path.
Another approach is to load all the files from all the folders that you want to treat and then filter to see just the ones that should be grouped together.
You could also sort files by folder if you add a column with the folderpath.
Or you use the WIndows Explorer and drag&drop the folder that has files for treatment into MP3tag.
So you see, there are many ways already. Try to apply those until your suggestion has been implemented
