Search and edit does not ask to save changes
Small bug here. Nothing major but since you fixed the ask to save when you edit awhile ago figure you might want the same function on the find and edit / save.
  1. Click on Find.
  2. Search for something like Petty
  3. Select one of the songs and edit something in the tag
  4. Select another one of the search results
Expected: It should ask if you want to save the changes or not.
Actual: It just goes to the next selection and if you click back on the original selection the changes are gone.
Thanks for reporting! I'll look into it and keep you posted.
This is now fixed with Mp3tag v3.35-beta.3.
