Search for text
is there a way i can do a search for a particular of text in the title. for instance, i want to be able to quickly search for the word "feat" in the title field, have it hightlighted so I can modify it. ? I don't want to modify anything, just want to be able to seach for the word, have it highlight it so I can run a different action later.
The primary source of information:
Menu Edit>Find ... Ctrl-F
I am using that. I was asking is there a way to highligh the word instead of it searching through all the tag fields. I specifically wanted it only to look for the word in a particular field..such as Title.
Highlighting makes no sense if you enter a regular expression that looks for files that do NOT feature a particular string.
If you want to limit a list to certain field:
for instance.. if I type in the filter box artist IS "Amerie"... i get the results..
but if i wanted to seach the Title Field for Why using title IS "Why" I don't see anything.
That is because there is no TITLE with just the single word "Why".
Try the operator "HAS".
THANK YOU!! THAT DID IT.
PS. Is there a list of other operators? I'd like to reseach further.
What about the linked section from the documentation?
It would speed up things considerably if you took the supplied information seriously.
thank you kind sir. :slight_smile:
