Searching some double spaces
Good day,
I would like to know how to search the filename which contains some double spaces.
Thanks for your help
Try the filter expression
´%_filename% HAS "::"`
(where the 2 : represent the space characters, but as the forum formatter swallows multiple spaces, I used the : to illustrate))
Thank you very much for your prompt answer
All i OK
