I want to move the BPM numbers only to the BPM field from the file title tag.
I know that \s((.*)) will remove all inside and the parentheses also.
I can't seem to figure out how to search within and only move the numerical data to the bpm field without the text. Since one file has 3 digits and the other 2, I'm not sure how to do this.
I used it as the action, it puts the numbers into the field and nuke it off the title cleanly.
Thank you very much. I will try to understand the script a bit better. I understand the %% operators, the \d operator, and the $ operator, just not the contruction of the syntax to execute the task.
I don't know what you are missing. Both of your strings still have the litteral parentheses (or parts of them) in in them ( and ).
They are not needed here.
And you write -(\d+) but in the examples it's -102 and -97 . With the minus on the left side of the digits.
Your right, that is my lack of knowledge of that area, I was trying to see if I could figure out what to do to fix it without the knowledge of the consequence of the actions I was doing.
I've learned a lot, hopefully this will add to that knowledge base. It works the way I need it, thank you once again!
