I have a lot of existing tags that contain secodaryartist tag, is there a way
for MP3TAG to edit/read these?
SD
SD
Just have a look at the extended tags dialog at View > Tags... [Alt+T].
Best regards,
Florian
Thanks I see the tag now.
I have a tag under extended, it was created with Helium called #HELIUM FEATURED ARTIST
is there a generic tag I should use for a second artist?
I have created a field called SECONDARYARTIST is this acceptable as proper tagging?
SD
Figured it out..
BTW. Great Program !!!
SD
I don't know it exactly but I think the BAND-tag is a field where you can put in such data. But creating own fields isn't forbidden.
But be aware that those fields are not always supported by other progs.
A similar discussion is going on here
I've created a tag and called it SECONDARYARTIST, I had the data in before and I need it for
file naming purposes. The program works great.
Thanks
I'll have a look..
Thanks
