Hi!
I see how I can select multiple files when tagging - I would like to do the
same when selecting folders to import into the tagging view. Instead of
adding one folder each time with the button I'd like to click and select
a bunch of folders....Possible?
Also, is it possible to change the sorting order of the folders, so
the newest files comes first...the ones I need to tag...
Maybe there is even a simpler way of doing all this?
Thanks Florian!
Drag& Drop works but when I try to drag and drop multiple folders
at the same time it seems to work fine (I can see that I drag several folders)
until I drag it into the MP3tag screen, then my multiple folders becomes just one. And I have to do them one at a time.
Hmmm?
