Hi all,
I want to set (insert) some variable information about the file in the comment field (as default). And whenever I tag files, to be able to select that string with variable information and that information to be inserted into the comment field of the file. For example, I set (type):
%_samplerate%; %_bitrate%
and the specified information for every file to be inserted into the comment field. Example:
48 000Hz; 128kbps
Hope you understand what I want. Is this even possible to be done? Because I tried once and with no success :-(.
Thank you for your help in advance!
Best wishes!
Kostadin Kolev
