You will still get the TRACK in the main tag info window resulting in it tagging the TRACK TAG.
There's a solution by placing 500, for example (Which should be enough), |'s at the end of your script like so in conjunction with # set "TRACK" (Optional) if you place that option at the end:
outputto "track"
say "||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
# set "TRACK"
I'm pretty sure this may be a bug. But, I'm not certain. Anyway, here lies a solution.
# Delete TITLE Field
set "title"
outputto "title"
say "|"
# Delete TRACK Field
set "track"
outputto "track"
say "|"
I did quite a lot of testing until I had it going. I think I remember it's important to use the two command blocks in this order to get both working. And to use it at the very end of the script.
set "title"
outputto "title"
say "|"
set "track"
outputto "track"
say "|"
So the initial bug find is there you think?
I've been busy so haven't had time to source the script which I had problems with. Think I may have deleted it.
