Considering that in this panel it is possible to decide via check which data to write in the mp3 metadata once downloaded from beatport, couldn't we integrate a shortcut panel where presets can be saved?
Es. with check (Cover only; bpm only, title and author only, etc.) depending on the user's needs.
This would eliminate the many files
es: Beatport by &stevehero v6#ARTW&ORK Search by (Album)Artist + Release.src (for the cover only, etc.)
