Settings Syntax Error - ERROR(Settings): expected value, got 'A' (65)
Re-added 0.6.1. Reinstalled 3.29. Same Error...
Script Error Log Text: ERROR(Settings): expected value, got 'A' (65)
Is there a file A&udible API#Settings….settings next to your Audible API.inc?
If it's named differently, can you rename that to the file name I’ve referenced above (with the three dots Unicode character). It’s looks like the app you use for unzipping the file doesn’t support those (7-zip for example, does).
Ah! Ok. I used the Windows 11 "extract all" built in right click option. 7 zip extracted as you said and I re-added that file. Now there are two settings files in the dropdown, the correct one and the old one. The "open configuration folder" option takes me to
C:\Users%\AppData\Local\Packages\35795FlorianHeidenreich.Mp3tag_rf0p6xgxmspcc
but there's no old settings file in the "sources" folder... just the correct one. Thoughts?
EDIT: Was doing this all as I was getting the "sorry no entries are matching your search criteria" when using the API Audible.com Author+Title option... still getting that error.. .
Can you provide a screenshot of the contents of your sources folder?
Yep... here you go...
Ok figured it out.. had two installs of it.. one in the packages and one in the main appdata. Will delete the bad one.
