Shifting any word based on dividers. Is it possible?
#1
Have finally got clean mp3s after my yesterdays attempt to find solution, which the generous member here helped me get.
now I have mp3s in this format mainly,
01 - Artist 1 - Title (Original Mix) (feat. Artist 2).mp3
thats the case in all the files.
As you can see there are 2 dividers.
I would want to achieve all the mp3s like this please.
01 - Artist 1 feat. Artist 2 - Title (Original Mix).mp3
*the feat. artist is always inside ( & ).
*the feat. is always feat.
*Format of tracks is TrackNumber Space Divider Space Artist1 Space Divider Space TitleOfTrack
*Its not necessary that (feat. XXXX) is at the end of filename. It can be anywhere in between also.
Can it be achieved?
Thanks for reading.
Best regards,
#2
Why do you fiddle about with the filenames?
Transfer the data to the tags first and then see e.g. this thread:
/t/11096/1
It deals with a lot of occurances of featuring artists.
#3
Thanks. I read it. But I dont know what regex to use in my case.
#4
Have you transferred the data to tags?
#5
Yes original tags looks like this,
Artist: Mark Jous
Title: Sandra (Courage & Evenfall Remix) (feat. Eufonic)
REGEX I am using is : $regexp(%artist%,$1,1) $mid(%title%,$strstr($lower(%title%),feat.),999) - $regexp(%title%,$1,1)
After result,
Artist: Mark Jous feat. Eufonic)
Desired,
#6
The regexp look overly complicated to me.
Check out the possibilities of a helper fields and guess value actions:
Move "Featuring" from Artist to Title
#7
I couldnt get what this link says.
Regex I tried my best to arrange in this order. Sorry not that into technicality sire. Please suggest a solution as per my case.
EDIT :-
$regexp(%artist%,(.),$1) $mid(%title%,$strstr($lower(%title%),feat.),999) - $regexp(%title%,(.) ((.*)),$1,1)
Worked.
Now the new tags are fine.
Earlier :
Artist : Mark Jous
Title : Sandra (feat. Eufonic)
Now after the regex it looks like,
Artist : Mark Jous feat. Eufonic)
Title : Sandra
Now I need to know the way to remove parenthesis after Eufonic that I am getting. Dont know how to remove that. What to add in the regex above?
#8
Create an action of the type "Guess value" for %title%
Guessing pattern: %title% (feat. %featartist%)
Create an action of the type "Format value" for ARTIST
Format string: %artist% feat. %featartist%
Delete user-defined field FEATARTIST
#9
GUESS code just adds (feat.) at the end of title. What am i doing wrong?
#10
I don't know.
Perhaps spelling, case?
It works with the given example.
#11
Sorry for the late reply.
It worked!!
How to do with these kind of examples?
ARTIST = Dirtcaps
TRACK = Foreign Tongues (feat. Eleni Drake) (Acoustic Version)
DESIRED
ARTIST = Dirtcaps feat. Eleni Drake
TITLE = Foreign Tongues (Acoustic Version)
Thanks and best regards,
:slight_smile:
#12
I would use an action of the type "Replace with regular expression" for TITLE
Search string: (.) (feat. (.) ((.*))
Replace string: $1 $3 (feat. $3
Which should lead to
TRACK = Foreign Tongues (Acoustic Version) (feat. Eleni Drake)
and then the already working "Guess value" action.
#13
got the result after doing,
$1 $3 (feat. $2
Thanks a lot :slight_smile:
