Hi to all
I created a file named "Mp3tagSetup.ini" with the following content in the setup folder :
[main]
program=1
smfolder=Mp3tag
[shortcuts]
startmenu=1
desktop=1
explorer=0
quicklaunch=0
[addons]
quickpick=0
[language]
language=1036
The command line used : C:\Mp3tagSetup.exe /S
The silent installation does not set the French language into the application, is it normal ?
The others features are setting up correctly.
Best Regards.
