Simple Action Question
I want to replace the title with the File name
Field: TITLE
Original: %title%
Replace with: %_filename%
The above doesn't work so I guess I don't know what I'm doing ...lol
No comment ...
Use a different type of action for this task:
"Format value" for TITLE
Format String: %_filename%
Or you could just as easy use
Convert > Filename - Tag
Enter
%title%
as mask.
thanks... like a newbie I didn't read the regex examples in the forum .. I found the answer already posted here also:
/t/521/1
