Hello, at first, I wanted to create my own "code" by folowing some manual... But Since I didn't find any tutorial on how to create those, I manage to create something.
Merci Milka, you got some of my problems resolved, however the "sort by track number" function dosen't work like it should:
1 - Wayne Static of Static X - Queen of the Damned - Not Meant For Me
10 - Static X - Queen of the Damned - Cold
11 - Earshot - Queen of the Damned - Headstrong
12 - Dry Cell - Queen of the Damned - Body Crumbles
13 - Tricky - Queen of the Damned - Excess
14 - KidneyThieves - Queen of the Damned - Before I'm Dead
2 - David Draiman of Disturbed - Queen of the Damned - Forsaken
3 - Chester Bennington of Linkin Park - Queen of the Damned - System
4 - DefTones - Queen of the Damned - Change (In The House of Flies)
5 - Marilyn Manson - Queen of the Damned - Redeemer
6 - Papa Roach - Queen of the Damned - Dead Cell
7 - Godhead - Queen of the Damned - Penetrate
8 - Jay Gordan - Queen of the Damned - Slept So Long
9 - Disturbed - Queen of the Damned - Down With The Sickness
Would it be possible to make the filename has the same name as the folder in wich are the songs ?
HOwever, I want to add static test with lots of odd ascii caracters in it.
Every time I try to add it, I end with a error message like: [ SYNTAX ERROR IN FORMATTING STRING ]
Is there a way to mark lines as comments so they wont be taken as code ? It don't even work if I remove all the "$" in my ascii text.
