Hi All,
I searched for a bit, but couldn't find anything that I could really do... I am sorry if this is old news, but I can't figure out how to do a simple find and replace inside the artists tag.
On about 1000 mp3's I am hoping to find "Scott" in the ID tag for Artist, and replace it with "Doug". I have never used regular expressions so I'm lost. Could you help me. Also, you can treat me as a super novice. I won't be offended.
There is no real "find" in MP3tag. But you can filter. For your example yo can use the filter
%artist% HAS Scott
Then select all the filtered files and create an action or use an Action (Quick) -> see toolbar for that.
Select the type "Replace"
Select the field ARTIST
Enter as search string:
Scott
Enter as replace string:
Doug
Click OK
