Often i will have an album and all I need is the cover. I get the cover from Amazon but here is where it gets tricky. I want the cover but do not want the Amazon tagging- so I right click the cover, extract, then (careful to not click ok but CANCEL instead) go to album cover on left and right click to add- select the cover and save.
Would be nice if somehow there were a simpler way- thanks!
the issue is not that I don't get useful results- it is that once you get them you have to do extra steps to prevent messing up the existing tags. I have no problem searching the net for covers if I need them.
