Hello Everyone
So far, I have alternately applied the Auto-numbering Wizard and a Filename-to-Tag format string to renumber tracks to display a leading zero, for eg. 01, 02, 099. Now, skipping any one of these two methods, and using only the Filename Field:
If any number, and sample, of tracks, which almost invariably preceded by a track number in some format, are to be auto-renumbered to display the required leading zero in the Track Field, how will this be achieved through a single action? Is it possible to derive at a solution at all, in spite of the many different ways in which the track numbers are usually integrated with the Filename? To name but a few examples:
1 File Name
- File Name
1 - File Name
01 File Name - File Name
01 - File Name
99 File Name
100 - File Name
Thank you for your assistance.
