Raven
May 24, 2026, 1:22pm
1
I have a few thousands of tracks currently, and plan to build a much larger storage. Mp3tag need to load for 30s now. Would it be way faster using installed program than portable?
See e.g. this thread:
I have been noticing sluggish performance on this last build and it has gotten progressively worse. I do not see others reporting this, so maybe it has to do with my system, but other programs are not exhibiting the same "sluggishness."
Basically, when I select a tract to work on it, the track highlights and everything pauses for 3-4 seconds before I can work on any field. If I click on any field during this time, nothing happens. Once this 3-4 second pause happens, I can jump to any field a…
The speed does not depend on portable vs. standard installation but on the rest of the (hardware) environment
