Slow Saving Of Tags With 24-Bit Files
Not sure if this is a bug, but I've noticed mp3tag is VERY slow when saving 24-bit files. It seems relatively quick with higher sample rate files (48k or 96k) and 16 bits, but quite a bit much slower if it's a 44kHz file at 24 bits.
Love, love the software....
Have you checked if the files you compare all have enough padding and also that they are encoded with the same flac version? Otherwise they're not really comparable.
Understood. I thought it might be something related to how the files were created. Thanks!
