I have some questions popped out about exporting in Mp3Tag, which I hae not been able to find solution for so far.
How to Append to XML file without duplicating parent nodes (looping childnode only), when exporting multiple times? Looping childnode Works fine in single export.
Any text in the export file that is no code word is output for the export.
So, if you put that header between the filename declaration and the first $loop() statement, it will be output to the file only once.
I do not know what you mean by that. Any file with the same name overwrites an existing one. You can disable messages in File>Options>Messages and see if that works for you.
<?xml version="1.0" encoding="UTF-8"?>
<DJ_PLAYLISTS Version="1.0.0">
<PRODUCT Name="rekordbox" Version="4.3.1" Company="Pioneer DJ"/>
<COLLECTION Entries="149">
.Dot
A. F. Study II
Afloat
Akzent
All-Ein-Samkeit
Alone? Lonely.
Altsein als Alternative zum Altern
As If In A Dream
AuroriWOW
Bach: Präludium...
</COLLECTION>
</DJ_PLAYLISTS>
I do not see any repetition outside the $loop() statement.
Probably loop item makes the difference then, I tried to loop by filename, instead if title
Still makes me wonder, when you loop by %title%, what would happen if you hit second track with same title?
AFAIK, it would skip it, hence why I chose filename...as it would be most likely unique.
And? have you replaced %title% with %_filename%? It should make no difference in repect to which part of the export file gets repeated and which doesn't.
