I'm using this to capitalize letters after certain characters:
FIELD: ALL
CASE CONVERSION: Mixed
WORDS BEGIN FROM/AFTER ANY OF: (-.[
The problem is this also names my files .Mp3 rather than .mp3, I need a way to tell it to not capitalize .mp3.
I also need a way to search for exactly what I type in the filter (case sensitive), at the moment it seems to throw a bunch of results back regardless of the case I use in the search.
You can add an action that will re-lower the file extension using a formula like this:
_FILENAME_EXT <== $lower(%_FILENAME_EXT%)
... but I do not know how to do it in detail .. the summer abstinence put me totally away from Mp3tag scripting.
Hmm, maybe this way works ... Actiontype 4: Replace with regular expression Field: _FILENAME Regular expression: ..*$ Replace matches with: \L$0
A filename like "Some.Test.File.MP3" or "Some.Test.File.Mp3" will be converted to "Some.Test.File.mp3".
DD.20100813.1052.CEST
There is another simple solution for just lower casing the file extension using the converter "Tag - Filename".
Convert | Tag - Filename | ALT+1 Select format string
Format string: %_FILENAME%
Because of Mp3tag's "behind the curtain" feature of formatting the file extension to lower case, a given filename of "some OTHER test file.MP3" will be converted to "some OTHER test file.mp3".
