The advantage of the comand shell is that it shows the files as stored in the file system and not sorted by some other criteria
e.g. like this:
ok, command prompt is on
navigate to the drive and folder where the music is stored.
If d:\vidovdan ... is the correct path, type in:
d:Enter
Prompt should change to d:\>
cd vidTabEnter
Prompt should change to the whole path
Type in:
dirEnter
Also, see this thread:
