You can see the order in the photo and I have clicked on the top of the column but the order starts from #20 down to #1 but the Discogs lookup assigns the track names in the other direction.
How can I get it in the correct order? Also I need to know how to make the filenames match the track names. Thank you.
The sort order in the File List of Mp3tag is not the same as the sort order in the Websources-Script for Discogs. You have to sort the tracks inside the website result window again.
We cannot see the track-column and we can neither see the header of the column you sorted with in your screenshot.
After a click on a column header the items in the column get sorted in ascending order. You can see that by the little arrow in the column that shows up. To reverse the sorting just click again on the column header.
