I found my old walkman when unpacking and just thought it would be a "quick 5 minute job" to update the music library and have a listen.
Wrong!
I kept one music folder on the walkman and got rid of the few other folders, and copied over some mp3 folders. After battery recharge, pulled the plug and "music library updated". But no tags for artist, album etc seen except for the original folder. Music plays back ok but all you see is the filename.
Saw Florian's tag on unicode support and tried that but no difference. In mp3tag the tags for the good files (display artist, album etc) and bad files (nothing) look identical.
I looked at other tags I could display but nothing looks different. Can I display other tags or info that might show the differences e.g. unicode version.
Any other clues or info?
Thanks
p.s it's an NWZ-A818 but could not work out how to change the title
mp3tag shows the Tag column as ID3v2.3 (ID3v1 ID3v2.3) for "good" and "bad" files... so apart from filename and tags like artist,album, genre, etc all the other tags I can see in the default columns are the same e.g. frequency 44100 hz, mode stereo, etc,
Could it be that some files are VBR and the others CBR? The lame-header indicates VBR.
MP3diags lets you remove superfluous LAME headers.
There is a utility mp3packer that can fill frames so that they become CBR.
it's the good file that has the LAME header and the bad file doesn't have the LAME header... maybe there'a a way to add a LAME header... although both sets of files play fine in foobar and on my sonos system
Can we stop the guessing here?
You can go through all the properties (e.g. cover size may be an issue or that the data has umlauts in it and so on) and see where the important differences are.
But that will go quicker if you check it on your system. I cannot look over your shoulder.
Have you filled the field ALBUMARTIST?
I think my old SONY NX70 was only willing to identify an album if that field was filled.
Also, all files for an album should have just one folder on their own.
The YEAR should be identical.
