Sort Order on Actions Not maintained
it seems that if the actions sort order is modified (using up and down buttons), and then closed via 'close'..without running an action via 'ok' the sort order changes are not maintained.
Unless do actually execute an action you have to explicidly save the modifcation with the button "Utils>Save". Close alone does not save (as you have seen).
ah..missed that..ty
