is it possible to sort the artist coloumn by the number of titles a artist has?
So that I can see who has the most titles in my Library and the less.
I need it because i need to edit all titles to check correct Information.
And I wanna start with the complete Artist/Albums.
I have a lot of Artists.
And the ones with only 3 titles etc. arent interesting for me.
The ones with most titles need to be edited and have highest priority.
Thats why I need to sort them by the mass of Albums or Titles.
... If It's possible
I can only think of really turning the whole collection upside down to get all the tracks of one artist into a single folder and then use the numbering wizard.
But I would advise to use WMP for this purpose.
I once had a similar task. The only difference was that I wanted the know which were the not complete albums with the most mp3s in it, just to to start tagging with them.
DetlevD helped me to fing a solution in this german thread: /t/9623/1
2: $loop(%ARTIST%)$puts(CountFiles,0)$loop(%ARTIST%)$loop(%_path%)$puts(CountFiles,$add($get(CountFiles),1))$loopend()$loopend()
3: $loop(%ARTIST%)'"'%ARTIST%'","'$get(CountFiles)'","'%_path%'"'
4: $loopend()$loopend()
5: $puts(Info,'This Mp3tag export script creates a report text file of format CSV (comma separated values).')
6: $puts(Info,'The CSV columns are: "Artist","CountFiles","Filepath".')
7: $puts(Info,'The CSV output list is sorted by "Artist".')
8: $puts(Info,'The CSV column "CountFiles" contains the sum of files per artist, which have been collected from the files of the related Artist.')$puts(Info,)
You have to import the report output file into the selected files, ...
using the converter "Textfile -Tag" with a format string like ...
"%DUMMY%","%SumOfFilesPerArtist%","%_path%"
The import process complains about empty lines, which cannot be parsed, this can be ignored.
You have to create a column in the Mp3tag grid view for the new tag field ...
Name = SumOfFilesPerArtist
Value = %SumOfFilesPerArtist%
Numerical = yes
