Had a minor disaster the other day, upgraded itunes and for some reason I lost half of my composer tags. Typical as i had just two days before bought a new backup hard drive to back up everything to! anyway, i still have the sort composer tags that i can copy back to the composer tags. Only thing is, i have to change them back into the correct format. No problem with the actions for doing this, but I was wondering if i could set up a column that would sort the sort composer tags into length order. E.g
Weatherly, Frederick, Edward, Cash, Johnny
Watts, Whiteley
Warner
Webb
into
Webb
Warner
Watts, Whiteley
This is so I can just whip out the single name composers and copy them accross to the composer tag, saving me a bit of work!
I have set up another sort composer column, but cannot work out how to sort by word length.
Many Thanks
Steve
