Hi everyone,
Maybe someone could help me. Is it possible to sort the list of files on multiple columns on the mac version? I tried everything I could think of, but no results. The sorting is always on one column.
Regards,
Angelo
Hi everyone,
Regards,
Angelo
Hi and welcome!
You can either sort by Column 2 first and then by Column 1 or create a dedicated "sorting column" via Preferences β File List that has a format string at Sort by which resembles the different criteria you want for sorting, e.g., %_path% or %artist%%year%%album%$num(%track%,2)
Hi Florian,
Thank you for your fast reply. But I don't understand what you mean by sort by Column 2 first and then by Column 1. When I click on a column it will sort, but when I click on another column it will sort on that column.
But thanks for the hint in the Preferences. I did not know that File List was used for that. I will look into this.
This is the way I do it, and it is very helpful. For example, my "Album" column displays %Album% but is sorted using this logic; %albumsort% %discnumber% %track% %title%
Plus that way when you click on the column, it will always sort with this method.
Thats smart
Thank you for sharing this. I will make use of your idea ![]()
