Hi, first sorry if this already was asked before
I was using the batch convert tag to filename and faced with some tags with special characters like ": \ | ?" that I guess none file system support, I'd like to know if there is a way to map substitutes to them when we use this kind of bulk function.
I'm asking this because I've seen such feature in the other software "Exact Audio Copy" and I thought that would be perfect for MP3Tag.
that's exactly what I was looking for, thank you!
So the syntax that I used for two replacements was: "$replace($replace(%title%,:,;),/,-)", is that correct? It worked here
I think you could simply use the $replace() that replaces the / with a -.
Unless you use $validate() and tell MP3tag to use a special character, all invalid characters for filenames would simply be left out. So there is no need to treat the :
