"Startswith" in a Filter
Can you please help?
I want to do a mop-up, having fixed a ton of tags in my library.
I'm filtering on before I started batch-fixing tags on the tenth, so I'm starting my filter with:
"%_file_mod_datetime_raw%" LESS 1688943600 AND
What I want for the second half of my filter is the ability to break these down into batches.
I figure the best way to do this is by albumartist's first letter, so I want something like:
"%_file_mod_datetime_raw%" LESS 1688943600 AND albumartist STARTSWITH "A"
What would be the correct syntax to achieve this?
Thanks in advance :slight_smile:
Try
"%_file_mod_datetime_raw%" LESS 1688943600 AND %albumartist% MATCHES "^A"
