Windows 7, Mp3tag 2.91
Problem: Stuck trying to assemble the correct parameter in Mp3tag Options>Tools, with which to open a file location — not using Windows Explorer to open the file location, but a different file manager called xplorer2, which is a portable installation on my C-drive.
I did try all of the different optional command parameters, but although they open xplorer2, the location always diverts to the Windows Desktop — never the actual file location.
Thank you for your assistance.
