Hello,
I created an action composed of 2 sub-actions:
The first (export function) adds the selected tracks to a playlist for my squeezebox if this track is not already present in the playlist (PLAYLIST field empty).
The second :
Format field (PLAYLIST field = "General" (PlayList name)).
Here is the problem :
These 2 actions work very well alone but when I chain them only the format value action works.
My export function does not work.
I have had this case before with other actions. Grouping them into a single action poses a problem.
If not, can we format a field (eg PLAYLIST) in an MTE file?
This would allow me to have only one action.
My MTE file:
$filename(txt,utf-8)$loop(%_path%)$puts(test,$if($eql(%PLAYLIST%,'Général'),,'#EXTINF:'file:/$replace(%_path%,'','/')
'#EXTINF:'%_length_seconds%','%title%
$replace(%_path%,'\NAS','volume2','','/')))$get(test)
$loopend()
