Hi, I like to move the lines freely in program.
lets see:
i opened a dir with mp3tag, there are 30 musics inside.
all 30 musics are listed inside program window... all ok.
i want music 22 go to music 13 place, and music 13 go to 22 location,
its was easy if i just drag and drop (the line) music there,
after i put several musics in a order i need, ill go to (tools-> autonumbering) and make the sequence i want. The musics stay in order i need.
OR
Make a shuffle button to mix the musics, so i can press this button several times, and when an cool sequence for my musics are found , i just number it in autonumber.
Why?
I dont like use playlists, i just put my radio to load the directory i want. And my radio dont have shuffle
I dont want the musics do shuffle all times i turn on the radio, i just want the songs playing in the order i need. And the drag and drop lines will be a cool add, to make playlists.
Best regards,
Miotto
OMG!!!
