I edit a LOT of mp3s... An EXCESSIVE amount....
Anyways, sometimes I'll have sets of say 10 cds. Box sets that I'm tagging.
When I deal with them sometimes I'll open all folders at once, sometimes one folder at a time depending on the action I'm doing.
It would be VERY cool if there was a way to... have either a Collapse column with a + that allows you to collapse all the rows in 1 folder down to 1 folder just showing the row, not allowing it to be edited. So that way all the mp3s in that folder are still loaded, just not being used.
This way I can edit one folder at a time with certain actions, without worrying about re-loading all the other folders.
I understand if this suggestion isn't wanted by many, but it would improve my workflow a lot.
Probably more so then adding tabs even!
MAYBE you could actually add a REAL file tree folder navigation panel?
This way I could either select one folder, or highlight multiple?
I suppose even this way would require multiple loading of the folders.
