https://docs.mp3tag.de/keyboard says
This is an overview of all keyboard shortcuts you can use with Mp3tag
so it would be good if it included all the keyboard shortcuts you can use with mp3tag.
E.g. CTRL+SHIFT+F5, CTRL+SHIFT+F8 and any others that are missing.
Those are not official ones and are given to users only when needed.
Still though "This is an overview of all keyboard shortcuts you can use with Mp3tag" is incorrect ... leading e.g. to my surprise when you asked me to use an Mp3Tag key which had been taken by a Explorer shortcut!
"This is an overview of most keyboard shortcuts you can use with Mp3tag" would cover it!
I would like to 2nd that ALL the keyboard shortcuts are listed. I hit F5 by mistake and all of a sudden it started to read a directory. I don't know which directory it was because it took a long time but I assume it is a refresh.
I've added F5 and Del to the list. Let me know if something else is missing.
