It would be nice if Help explained what the status bar numbers mean.
Esp. the two that sometimes appear as xxx/yyy at the left end of the right-most panel - still I'm guessing!
It displays the number of files shown and the total number of files loaded (when filtering). A bit more to the left is the number of tracks selected along with their duration and size.
Thanks, but I see two different numbers even with no filtering. It might be more like the number loaded and the number considered for loading, inc. some rejected as unrecognised type.
Anyway, enough guessing. I hope we can have an official explanation in the Help.
