Suggestion: relaunch not to sort playlist
If I load a playlist, exit and launch, Mp3tag reloads the playlist - great - but loses its order. It sorts by whatever column order was selected. The same if the reload is of a manually ordered list.
It would be good if the file list order was preserved.
Perhaps the root problem is in fact that loading a playlist or reordering doesn't clear the colum sort selection (indicated by a heading arrow). I'd prefer it if any operation that deordered the list cleared the sort selection.
I think this won't be changed in the near future. If you want to keep your custom order of the files, just create a playlist that reflects and saves this order.
Cheers,
Florian
I'm a bit surprised that the playlist case is not an easy fix, but OK! Thanks for considering it!
