Hello everyone.
I'm developing a (new) iTunes script and I've hit a wall. I'll try to explain my problem:
I would like to be able to select/input cover size for an iTunes source script. So far I've been able to 'cheat' a value in the "CurrentUrl" output, as
Total output:
output["CurrentUrl"]= https://itunes.apple.com/lookup?media=music&entity=song&limit=200&country=jp&width=1200&id=505371XXX where &width=1200 is the value I want.
This would be "easily" achieved if there was a way to 'splice' an output S into the current buffer, as in (example):
Script-Line : xx
Command : splice
Parameter 1 : Output "CurrentUrl" (or another)
Output : ><
Line and position:
results
would return
Line and position:
resitunes.apple.com/lookup?media=music&entity=song&limit=200&country=jp&width=1200&id=50537145ults
or some command akin to Replace where the second parameter would be an output. Then with further processing I could get the "1200" value to the artwork url.
PS: I know about 'Adjust cover' that would achieve the same purpose for this example, but a 'Splice' command could have other uses regarding WS scripting.
Thank you.
