Prerequisite : 4 CD with 120 tracks. The CD-Number data was set correctly.
I want to renumber the tracks. There are to suggestions to make a better MP3Tag:
Add a scond leading zero to theTracknumber. 2 Digits are not sufficient. May be make it selectable ?
I want to number the tracks in that way : CD/Track or CD/Track/Tracknumbers. I want to have an option to add the CD-Number to the track field. Then i can maintain the CD-Tracknumber inside the track schema even for older players.
At least i can incooperate the schema CD-tracknumber into the Filename.
