Support for import of ISRC and UPC code from IFPI
Hello,
IFPI have a public search engine for matching records where you can find ISRC and UPC codes as well as labels.
It is possible to download CSV file for these data. Would it be possible to create a way to import CSV information?
The search engine can be found here: https://isrcsearch.ifpi.org/
It is already possible to import data from text files:
