Swapping multiple words in TITLE
I've got song titles that are like this:
Main Titles [From "Delores Claiborne"]
and
Main Titles [From Delores Claiborne]
What I would like to do is make the title be
Delores Claiborne: Main Titles
Thanks,
Chris
To:
Action "Format value":
$regexp($regexp($replace('Main Titles [From "Delores Claiborne"]','"',),'^(.+?)\s\[(.+?)\]$','$2: $1'),'^From\s',)
Alternative:
$regexp($regexp($regexp('Main Titles [From "Delores Claiborne"]','\[From ','['),'"',),'^(.+?)\[(.+?)\]$','$2: $1')
Alternative:
$regexp('Main Titles [From "Delores Claiborne"]','^(.+?)\s\[From\s\"?(.+?)\"?\]$','$2: $1')
In the above expression change the string part 'Main Titles [From "Delores Claiborne"]' to the tag-field content you want to use, e. g. %TITLE%.
Use the expression with an action "Format value".
You cannot use this expression to change a filename, because the colon is a forbidden character for a filename.
And see there about Dolores:
http://en.wikipedia.org/wiki/Dolores_Claiborne
DD.20100825.0642.CEST
