As of Mp3tag v2.93a, these are the untranslated strings for the Swedish translation of Mp3tag.
_C_ABORTING Aborting...
_C_CANCELING Canceling...
_C_MNU_VIEW_FILTER_AUTOAPPLY Auto-apply filter
_C_OPT_ADVANCED_LISTCHAPTERS List chapters as separate files
_C_OPT_GEN_CHK_KEEPMOVEDFILES Keep moved files in file list
_C_OPT_LIB Library
_C_OPT_LIB_CHK_ENABLE Enable Library
_C_OPT_LIB_CHK_RESTRICT Only include these directories
_C_OPT_LIB_CLEANUP Cleanup Library
_C_WIZARD_TRACKS_DESC Assign track- and discnumbers
_C_WIZARD_TRACKS_DISC_BEGIN Begin at discnumber
_C_WIZARD_TRACKS_DISC_LEADINGZEROS Leading zeros for discnumbers (01, 02, ...)
_C_WIZARD_TRACKS_DISC_SAVETOTAL Save total count of discs
_C_WIZARD_TRACKS_DISCNUMBER Discnumber
_C_WIZARD_TRACKS_TRACKNUMBER Tracknumber
_M_STR_CUSTOMIZE Customize...
_M_STR_DEFAULTVALUE Default value
_M_STR_FIELDSIZE Size of field
_M_STR_FIELDROWS Rows
_M_STR_SB_CLEANUPDATABASE Processing files ... {1} of {2} ({3} cleaned)
_M_STR_SB_CLEANUPDATABASE_BINARIES Cleanup orphaned binaries
_M_STR_SB_CLEANUPDATABASE_COVERS Cleanup orphaned covers
_M_STR_SB_CLEANUPDATABASE_NONLIBFILES Cleanup non-library files
_M_STR_SIZE_LARGE Large
_M_STR_SIZE_MEDIUM Medium
_M_STR_SIZE_NORMAL Normal
_M_STR_SIZE_SMALLER Smaller
_M_STR_SIZE_SMALL Small
_M_STR_UPDATE_OPT_CHECK_RELEASENOTES Display release notes for new versions
