I'm finding it very difficult to tag albums where the number of tracks exceeds the window size of the Adjust Tag Information dialog -- the two sides do not synchronize when scrolling, and it becomes almost a matter of guesswork as to how the tracks will get tagged.
Anyone else experience this?
Would it be possible to have the two windows scroll together, which each row always lined up with so that tracks get tagged as expected?
Click on the bottom song on the left panel.
Click on the bottom song on the right panel.
sroll the panels, but make sure you can still see the highlighted entry
when the highlighted entries line up, the you know you're synched
An equally annoying thing is that the fonts or line spacing or line sizes or something are slightly larger in the one panel than in the other, but again, i just work around it.
