Syntax for Total Time in Folder/Playlist
Can someone please tell me the correct syntax to use to incorporate the Total time of tracks in a folder?
The default report actually shows this at the bottom right corner of the report but I cannot find a way to build that figure into a custom report.
Thanks
Ron
You can edit any export script as it is a plain text file.
So, you could copy and paste the section about the total time.
or have a look at the documentation and special placeholders in export scripts:
Thank you - solved my issue
