Hi guys... BRAND New to tagging. I need a quick action code to rename my filename like the first trace in my list. I usually manually go through to rename
but I know there has got to be an easier way. Please help.
I need to change from just 01 - Trackname to 01-01 - trackname
Thanks!
What data do you have in the other fields? I can see only TITLE and that seems to be a mixture of TITLE and TRACK.
Perhaps you separate the data first and then rename the files with the function
Convert>Tag-Filename.
If you insist to fiddle about with the filenames then you could also use the function
Convert>Filename-Filename
Source: %1 - %2
Target: %1-%1 - %2
