Tag fields reset on failure
Upon unsuccessful attempt to save tags, all fields are reset to the initial value (e.g. File is locked)
Is it possible to add "Retry" option to failure dialog
see the changelog (https://www.mp3tag.de/changelog.html):
[2020-02-15] CHG: added option to retry write to file operations if file is being used by another application....
An update would do.
